MF 40 Industrial Backhole with Perkins 152 Gas Engine ( 3cyl)
John Fowler
12-29-2000 07:06:41
My backhole engine started missing and making engine noise a few days ago. I disassembled the engine and found that a valve seat had came out of the head. After complete disassembly and inspection I need the following parts, engine head
( machine shop said the metal in head is not very good because it's been welded three times before for cracks),pistons,cylinder liners,crankshaft (crankshaft is already reground to .030 under mains and journals and out of specs now) and complete overhaul gasket set. If someone could tell me where there is a good place to get parts (new or used) at a reasonable price I would appreciate it. Also maybe a complete good used engine or complete rebuilt. I live in Missouri but, I'll go anywhere for parts. Thanks, John Fowler
lee (MN)
12-29-2000 21:23:04
 Re: MF 40 Industrial Backhole with Perkins 152 Gas Engine ( 3cyl) in reply to John Fowler, 12-29-2000 07:06:41
there must be a perkins dealer in st louis or kansas city. the 3.152 perkins is a cheap engine to o/h a complete kit is under $500. bucks. the head might be spendy?. the crank can be fixed i had a wd done last spring $40.00 a journal to weld them up, plus grinding. hope this helps.
