MF 202 steering problem
Mike Keers
12-28-2000 17:00:50
Hi gang,
I've looked thru all the archives regarding steering problems, and come away more confused than when I started.
I have a 202 loader, with power (assisted?) steering. The pump was replaced a few years ago, and the seal at the top of the steering column.
The problem is the steering works fine turning right, but it became increasingly difficult to turn left (after center). Finally, after the tractor sat for a few months unused, it will no longer turn left at all, even with the front wheels lifted off the ground, and all my strength on the wheel. It feels more "mechanical" than hydraulic...it seems the wheel almost comes up "hard" on center. This tractor has dual pistons (cylinders) mounted on the front axle, and dual steering arms (Pittman arms?) coming from the gearbox above the shifter.
I do not have a manual, but will buy one if I knew what to get...seems a selection of them out there. All I know is it's a 202 loader. I was told 1956, but the serial numbers here indicate it's more like a 1959-62. Any help, even in choosing a shop manual, is greatly appreciated!
Thanks for your time and attention.
MK
Dan Magers
11-29-2001 10:08:23
 Re: MF 202 steering problem in reply to Mike Keers, 12-28-2000 17:00:50
I have a 203 with a steering problem as well. I had the box off a few yrs ago and I still remember the 4 letter words used to remove it. I wonder if anyone has a source for a good used/rebuilt or even a kit to repair the steering box? There's not much info out there on the 202,203,205 series tractors. What parts from other models might fit. Anyone know?
Dan Magers
11-29-2001 10:07:25
