mf #3 baler breaking twine at knotters
outthere
03-22-2008 08:38:21
Planning for hay season. I have a #3 baler with #10 knotter. When I have light windrows the twine seems to break or excessively frays. I had it serviced and it cost more than the baler was worth. Corrected some of the problem, but problem still lives on. Is this a common problem? Any troubleshooting ideas would be helpful. Thank You
Gerald J.
03-22-2008 11:46:59
 Re: mf #3 baler breaking twine at knotters in reply to outthere, 03-22-2008 08:38:21
Check the entire twine path for rough or sharp edges to holes and for grooves worn in guides. Fix 'em.
Gerald J.
outthere
03-22-2008 18:10:47
 Re: mf #3 baler breaking twine at knotters in reply to Gerald J., 03-22-2008 11:46:59
the guides- meaning the insulators that the twine runs through? If thats what the guides are they do have grooves that the twine fits in. Do they need replaced or is this normal wear.
Gerald J.
03-22-2008 20:16:55
 Re: mf #3 baler breaking twine at knotters in reply to outthere, 03-22-2008 18:10:47
The grooves are normal wear, but they mean a slightly fatter twine than what wore the grooves drags, pinches, and catches. You can get out of the grooves by turning the porcelain insulators. Those grooves have sharp edges that can cut twine too.
Gerald J.
msb
03-22-2008 10:13:56
Have you sharpened the twine knives?
DavidP, South Wales
03-22-2008 12:44:21
 Re: mf #3 baler breaking twine at knotters in reply to msb, 03-22-2008 10:13:56
Hi,
Where is the twine breaking? The cord held in the knotters is referred to as the number one twine and the twine brought up by the needles is the number two twine. Which side of the knot is it breaking on?
DavidP, South Wales
outthere
03-22-2008 18:14:42
 Re: mf #3 baler breaking twine at knotters in reply to DavidP, South Wales, 03-22-2008 12:44:21
it is typically after the billhook. There is a knot but the front side of knot facing driver is intact. the twine that is on the backside of the knot is broken. It is typically the driver side knotter.
DavidP, South Wales
03-23-2008 06:41:21
 Re: mf #3 baler breaking twine at knotters in reply to outthere, 03-22-2008 18:14:42
Hi,
If I understand you correctly the knot is present on the number 2 twine and the break has occurred on the number one twine. You mention the driver side but for us in the UK that would be the right hand side!!! So I assume its the left hand knotter.
I think that the knot will be coming off the billhook OK but it is then getting caught on a projection in the bale case. This projection is probably in the vicinity of the twine finger. That is the finger that places the No 2 twine into the twine disc. The 'twist' in the cord can cause it to fall exactly in the right place to catch. Have you observed the knotter operation while someone drives the tractor or feeds the baler?
DavidP, South Wales
