MH33 seat
old
03-21-2008 13:16:23
Any body have a picture of the seat spring on a 33 row crop. The 33 I have is missing the lower spring mount and I would like to make one but want to make it as close to what was on it as I can so I need a picture or 2.
Thanks
44 massey
03-21-2008 15:35:35
 Re: MH33 seat in reply to old, 03-21-2008 13:16:23
Sent you some pics of mine,,,,, ,,hope they turn out okay. Tractor is in the shed tarped, kind of dark!!!!
old
03-21-2008 16:25:42
 Re: MH33 seat in reply to 44 massey, 03-21-2008 15:35:35
Really hard to see them because of the size of them and the hyd. lines that I do not have. I tried to use one from a NH30 and it doesn't work because its not off set to the side like your pictures show. Plus the ones your picture shows looks like its cast iron so theres no way to reproduce one of them but at least I have a good idea of how it should sit. Thanks
44 massey
03-21-2008 16:51:38
 Re: MH33 seat in reply to old, 03-21-2008 16:25:42
yes it is cast iron, my parts book shows no. 763-955-M1 or 766-788-M92! The one on my parts tractor is already gone,sorry and the 44 is different, much like the 30! The 766-788-M92 is for later models and looks l like steel plate. As I measure it the spring seat is about 8 1/2 inches above the trans deck plate and about 3 inches to the rear. Maybe use a piece of 8inch channel iron and knotch it out for the cylinder with a bracket welded on top for the spring to set on?
old
03-21-2008 19:35:13
 Re: MH33 seat in reply to 44 massey, 03-21-2008 16:51:38
Well now that I see what it should look like I will probably take a piece of pipe and bend it in a sort of S and make it work. As it is the spring is from an Allis WC
44 massey
03-21-2008 14:41:38
Might happen to have one, have a 33 and 44 parts tractors will take a look and see!!
Kirk-NJ
03-21-2008 13:28:54
I put a photo in the parts and pieces section under MH spring seat. I got this off a MH but I'm not sure what model it was. If you need more photos I can take them and send them via email. Just let me know.
Kirk
old
03-21-2008 15:35:37
 Re: MH33 seat in reply to Kirk-NJ, 03-21-2008 13:28:54
Just looked and I didn't find it
44 massey
03-21-2008 15:40:29
 Re: MH33 seat in reply to old, 03-21-2008 15:35:37
What is your email???
44 massey
03-21-2008 16:00:51
 Re: MH33 seat in reply to 44 massey, 03-21-2008 15:40:29
mmmmm mm,,,,, ,,,,, ,,,,thats where I sent it!!!!!
old
03-21-2008 15:46:31
[email protected] Its also in my web page if that would make it easier for you
44 massey
03-21-2008 16:23:08
 Re: MH33 seat in reply to old, 03-21-2008 15:46:31
just sent them again!!!!! !!!!
