Steering gear/pedistal
old
03-20-2008 12:23:49
Will the steering from a MH 30 fit on a 33. The steering on my 33 is very bad as in a full turn to get it to even start to turn the front wheels. I have a 30 parts tractor with a good tight steering box but it has a broken spindle so I want to either change the spindles or take the 2 and make one good one.
Thanks
44 massey
03-20-2008 18:42:26
 Re: Steering gear/pedistal in reply to old, 03-20-2008 12:23:49
According to my parts book,,,,, ,,the 30 and the 33 take the same steering gear box. . As for the front spindle support (casting) the 30 casting will fit an early (prior 2742)33 but not later (2742 up)! The 30 and 33 show different spindles, would think if you have the pre 2742 33 you could swap the complete castings with spindles! Hope this helps ya out.
old
03-20-2008 19:46:01
 Re: Steering gear/pedistal in reply to 44 massey, 03-20-2008 18:42:26
Well I ended up taking the steering box that holds the worm gear off the 30 and it bolted right down in place of the wore out one on the 33. Both bearings in the 33s box where gone but the ones in the 30 box was good. 4 bolts and the steering rod and it was off and back on
44 massey
03-20-2008 17:59:45
Hold on,,,,, ,,,,, will run out and get my parts manuals and check,,,,, ,,take it your talking about row crops I hope,,,,, ,,,,thats the only manuals I have,,,,, ,,,,, BRB
Don_G
03-20-2008 16:35:48
Don't be discouraged. There are a lot of good MH people on this site. Perhaps one of them will be kind enough to help you out.
Don
GRJ
03-20-2008 16:17:18
Check your parts books for part number to see if they are the same. Duh
old
03-20-2008 16:43:13
 Re: Steering gear/pedistal in reply to GRJ, 03-20-2008 16:17:18
If I had one I would but I don't. I don't have a manual either so I'm just winging this one. But I did find out that they are pretty much the same since to main part of the steering box is now on the 33
