MF65 B4 pics
Don_G
03-20-2008 10:40:58
third party image
third party image
third party image
third party image
third party image
third party image
Jeff,
Here's some before pics
Don
lonestarjeff
03-23-2008 22:37:03
 Re: MF65 B4 pics in reply to Don_G, 03-20-2008 10:40:58
Don....enjoyed the b4 as well as the progress pics. Looks like you went all the way thru the tractor.
....inspires me to tackle the 165....if I ever get thru w/ the 860.
Jeff
Don Snyder
03-23-2008 15:42:36
Looks like you done a great paint job, but the grey looks like the grey used on the To 20 and To 30 Ferguson tractors. To bad the NAPA store guided you to the wrong color, it should be flint metallic grey which is darker.
Frank A
03-20-2008 15:50:11
It looks realy good. Is that OEM color gray paint?
Don_G
03-20-2008 16:02:44
 Re: MF65 B4 pics in reply to Frank A, 03-20-2008 15:50:11
The red and grey paint is from my local NAPA store. They called their distributor and got the paint codes for Massey Ferguson. I'm still not sure this is the correct grey for the year but once it was on I thought it looked OK.
Don
GPL
03-20-2008 15:39:15
Nice Tractor!!! I just purchased a 65 with a stuck engine. I removed head and found #2 cyl. sleeve sucked into the crankcase. Sure hope my tractor runs as good as yours looks! did you go into the engine at all?
Don_G
03-20-2008 15:56:53
 Re: MF65 B4 pics in reply to GPL, 03-20-2008 15:39:15
The engine work consisted of a new water pump, fuel pump, oil pump, main and rod bearings and rear main seal. Despite the very high hours, the crank was good and standard bearings and thrust washers were used. I think there had been some work done on the engine by a previous owner. It had a new injection pump.
Other work done was transmission seals and inner/outer axel seals and bearings, a complete new clutch with bearings, a complete brake job, all cross shaft, spindle and steering bushings.
If I wrote a book about this project it would be called
Tractor Meets Credit Card - A Love Story
Good luck with yours.
Don
