MF 135 Changing Spark Plugs
denny cooke
03-20-2008 09:01:55
Looking for advice on how to change spark plugs on Massey Ferguson 135 with 3-cylinder Perkins engine. Does gas tank need to be removed to get to plugs? If so, any special tricks to get the tank off?
Steve IA
03-21-2008 04:09:37
 Re: MF 135 Changing Spark Plugs in reply to denny cooke, 03-20-2008 09:01:55
Tank is easy to remove if you want to. Remove 2 nuts on the back, disconnect the gas line (after shutting the gas off) lift the back of the tank and slide up and back. When it's off you'll see how the front is secured. It's a little tricky getting the front of the tank in the right place when reinstalling but it can be done. I hold the spring loaded bolt open with a screw driver handle to allow the tank slot to fit home, then remove the screw driver. You'll see when you get there. Good luck.
Steve
ltolson
03-20-2008 11:45:01
Don't need to remove the gas tank. Just take off the heat shield surrounding the manifold and you can get at the plugs.
Larry
