1150 Multi-Power repair
V8 farmer
03-19-2008 12:27:25
Just got my 1150 to the shop to fix leaking rear main seal and slipping Multi-Power. I opened the clutch pack and found one good friction disc, two bad ones and two that had completely lost their surfaces. Few of the small springs that push the clutch open were in bits and pieces, wonder what caused that??
Friction discs have left some notches to the gear they drive so I guess that needs to be replaced. And I guess it is wise to put all new sealing rings there too?
Would like to hear if there is something to look for, never done MP overhaul before!
Holm
03-19-2008 15:40:56
 Re: 1150 Multi-Power repair in reply to V8 farmer, 03-19-2008 12:27:25
I always replace all seals, rings,plates discs& springs when I do a 1100 series MP.I would also replace the gear with the notches worn in it.The MP is a very dependable system when repaired correctly. Harlan
V8 farmer
03-20-2008 05:21:21
 Re: 1150 Multi-Power repair in reply to Holm, 03-19-2008 15:40:56
Thanks for the opinion. Another question: I noticed today that those little release springs didn't have roller/needle in them like the parts book suggests. Also my AGCO dealer cant get those needles so are they necessary?
Wayne IA
03-20-2008 16:04:41
 Re: 1150 Multi-Power repair in reply to V8 farmer, 03-20-2008 05:21:21
Personally check with the local MF dealer and the pins and springs ARE available.
DavidP, South Wales
03-19-2008 13:07:36
Hello.
Is it possible that the tractor has been left in 'Low' MP for a very long time whilst working.
Although the clutch pack is almost immersed in oil it is possible for the plates to overheat as they are spinning against the driving plates in 'Low'.
Is there any indication around the clutch housing of overheating eg blueness of the metal?
DavidP, South Wales
V8 farmer
03-20-2008 05:27:11
 Re: 1150 Multi-Power repair in reply to DavidP, South Wales, 03-19-2008 13:07:36
I don't know the history of this tractor, I've had it for two years and the MP didn't work when I got it. Clutch housing and plates are not blue, but the gear that goes inside the plates is a bit blue at one end.
The clutch plates looked like the friction material was torn off rather than worn out. Might be that those little pieces of those springs got between the discs and caused that?
