Super 90 hydrolics
zlspencer
03-17-2008 17:50:22
I have a super 90 diesel and I have been looking for a rebuild kit for the hydrolic pump but cant find anything.I already have a manuel but have no idea what the pump model or parts number is.Can anyone help me?
zlspencer
03-22-2008 17:10:51
 Re: Super 90 hydrolics in reply to zlspencer, 03-17-2008 17:50:22
Hey I appreciate all the info its been a help
shawn brown
03-19-2008 16:11:32
i live in idaho and a tractor rcycler call nampa tractor salvage has parts for the hydraulic pumps on the 85 and 90 hydraulics other year pumps will also inerchange with this pump using newer and more acessible pumps , i do believe they also have rebuilt pumps
Robert Mull
03-18-2008 09:10:55
Give this guy a call. If he cannot get you one, you are out of luck. He got me a pump last year. 662-226-0099. He is located in Holcomb, Miss.
danthemasseyman
03-18-2008 05:18:10
If you are talking about the power steering pump, you will have a very hard time finding a used one of these as they haven't made them for years now and all the used ones have been taken as they were a weak point on these tractors. I put a Prince PTO pump on my Super 90 to operate the loader as well as a spare coupler in the back for something else. These pumps are rated at 21 gpm and work awesome, although they do tie up your pto shaft so if you do a lot of pto work, it might be a problem for you. They are simple to set up though, you just need an oil tank mounted on the back, the pump, and a two or three spool open center valve, which I mounted on the fender. I plan on hooking this to my power steering, but I will have to put in a priority valve so oil feeds the steering first always, as well as a flow and pressure control valve as the power steering system operates at quite a low pressure. Hope this helps.
willL
03-17-2008 18:29:16
I have not been able to find any dealer or after market suppliers for these pumps now for 5 years.
