massey 135 hydraulics
kemper
03-17-2008 08:31:38
Need some help with the hydraulics on a mf 135.
It has a 3 point log splitter and the problem is when splitting wood the 3 point raises first then it will split the wood then drops the 3 point back down, i have the control lever in the constant pumping position,and the tractor has (i assume)after market hydraulic valve to run the remote cylinder, it never used to do this and i have all 3 books but can"t figure it out?
DavidP, South Wales
03-19-2008 13:27:12
 Re: massey 135 hydraulics in reply to kemper, 03-17-2008 08:31:38
Hi, this is an interesting one.
I think your problem will be in the isolating valve on top of the hydraulic cover.
It is there to send oil either to the lift cylinder or to an external ram. If you have the selector set at 'halfway' you may be supplying oil to both services.
Initial oil flow will move your splitter ram to make contact with the log. When this can move no further the pressure builds up to a point where it is easier to raise the 3pt rather than split the log. When it has lifted it fully the pressure returns to the splitter and splits the log. When you retract the ram the pressure required for this is less than that to keep the 3 pt up and so it falls. What type of valve do you have? There are several types in the UK at least;
A simple push/pull for internal and external services.
A similar one with a collar around the outside which gives you a choice of one, two or three external ports.
Lever type; one lever normally selects the internal or external and the other gives you direct control of a ram.
Check also that your return line is larger than the supply and that it is fully clear.
DavidP, South Wales
