MF TO35 tire size
Fred Rose
03-14-2008 19:57:40
I have a 1959 MF TO35 which needs the tires replaced. Unfortunately the rear tires are in such bad shape that I can't read the size very well. It appears the size marked on the tire is 12 4-23, does this size seem right? Also there is very small raised numbers which read 2 DB 80-36911. I hope to find a set of used tires, if anyone knows a place near Central Calif the info would be appreaciated.
Fred T. Hart Jr.
03-15-2008 05:57:14
 Re: MF TO35 tire size in reply to Fred Rose, 03-14-2008 19:57:40
tire size: 12.4-28
apart of the cost of rear tire replacement is fluid transfer and mounting.
get a new set and you will be done with this project for years, if you do not run over a stob.
But check used equipment dealers, they may have a set. Most tractors that are junked out have junk tires.
good luck
