135 m f tractor
whitey m
03-14-2008 12:39:09
where is the serial number located on a 135 mf tractor
Gerald J.
03-20-2008 19:19:27
 Re: 135 m f tractor in reply to whitey m, 03-14-2008 12:39:09
On my MF-135 its on a plate below the dash about in line with my right knee.
Gerald J.
smokey2
03-16-2008 16:26:14
That s where it should be. Quite often removed while repainting and not refitted. I have a MF135 which lost its serial number plate in a fire. I will dummy up a replacement as I have the number recorded in old tax records. Use the engine number to get the date of build etc if you cannot locate the tractor serial number. Is the tractor a straight or bent front axle?
Wesley Stephens
03-14-2008 20:24:18
on the left side of the dash on the vertical part. ours doesn't have a plate, though, and there are no screw or rivet holes where one was. every other one I've ever seen had the plate in that location.
Stuart Brogden
03-15-2008 09:10:48
 Re: 135 m f tractor in reply to Wesley Stephens, 03-14-2008 20:24:18
Mine has no plate or holes in dash either.Where else would it be?
