Slipping clutch
Wallus
03-13-2008 13:54:06
Hi all. A friend of mine owns a Massey 135 that is showing possible clutch failure.It won't go into gear unless you shut it off and slips once you start it up. The pedal needs much less force to push it down and has much less travel. I'm no stranger to clutch repair (spent 20 years + in automotive transmission shops)but I keep hearing of a split torque design that may or may not be in this tractor. Are there any numbers that can tell me what type of clutch this has in it and can anyone tell me the function of the slit torque clutch. Thanks, Wally
david from mo
03-14-2008 16:35:52
 Re: Slipping clutch in reply to Wallus, 03-13-2008 13:54:06
The clutch you are talking about is used on ipto.A duel clutch is used on live pto and single disk clutch is used on the tractors that don't have ipto or live. not sure if the 135 had the basic single clutch. Pull it apart and fix whats wrong. david
Walluswormus
03-15-2008 17:23:46
 Re: Slipping clutch in reply to david from mo, 03-14-2008 16:35:52
Thanks for the replies folks.
And thank you David, we intend to pull it apart as soon as we pull it out of the snow bank(Har Har)
I'll let you know what we find.
Thanks again, Wally
135 Fan
03-13-2008 22:36:12
Are you talking about multi-power? It would have a lever on the dash but it does sound like the clutch needs adjusting or replacing. Dave
Kevin Meier
03-13-2008 17:28:44
Go to this site it"s where I work. There are pictures of the clutches you are aasking about>Link
just>Link copy and paste the site hope this sheds some light for ya.
Kevin Meier
03-13-2008 17:28:38
