CAV inj. pump an a 230 Massey
Fireman61
03-13-2008 05:13:32
How do i go about bleeding the air from the injector pump? Im evidently not doing it right.
chas
03-13-2008 11:26:31
 Re: CAV inj. pump an a 230 Massey in reply to Fireman61, 03-13-2008 05:13:32
Hi. Following is basically what it says in the book-
1- Slack the outlet union on the fuel filter
2- Operate lift pump until clear fuel issues, retighten.
3- Slack lower vent plug on injection pump - repeat 2.
4 - Slack upper vent plug - repeat 2.
5 - Slack 1 & 4 Injector unions.
6 - Slack thermostart fuel feed - Repeat 2.
7 - Throttle fully open, turn engine over on starter until engine begins to fire, retighten injector unions.
Hope this helps, e-mail direct if you need anything further, regards. Chas.
DavidP, South Wales
03-13-2008 11:37:27
 Re: CAV inj. pump an a 230 Massey in reply to chas, 03-13-2008 11:26:31
Hi,
Agree with everything Chas has said but first remove the pipe which comes from the fuel tap at the lift pump. Ensure that you have a positive flow of fuel coming through. Are your main filter/filters OK?
DavidP, South Wales
