Massey Harris 55 diesel primary fuel filter????
Kyle Ladowski
03-12-2008 20:40:41
I have a 1951 MH 55 diesel with the American Bosch APE pump and the two stage filter set up. I am having trouble locating a replacement primary fuel filter. I tried Wix, Napa, Massey, etc and no one can cross the massey number. The local auto parts and tractor parts places show 3 filters, but as far as I can tell they are all for the newer versions with three filters. I have the secondary, but can't find a primary.
Any help??
Thank you,
Kyle
Kyle Ladowski
03-17-2008 14:23:12
 Re: Massey Harris 55 diesel primary fuel filter???? in reply to Kyle Ladowski, 03-12-2008 20:40:41
Thank you all that replied. I got the filter today and they were right where Chuck said they would be. Now to try to get it running....
Kyle
massey333
03-15-2008 06:43:29
By my Massey parts book,it should be a Wix 33104,NAPA 3104,Baldwin Pf809 Fram F-1104.They cross over to several MH Parts Numbers..All the Primary Filters are the same as far as I can tell(2 or 3 setups).MY book calls for a 1 0065430m91.Hope this helps as Most of todays Parts people NEVER heard of Massey Harris.
chuck bergstrom
03-15-2008 12:19:25
 Re: Massey Harris 55 diesel primary fuel filter???? in reply to massey333, 03-15-2008 06:43:29
Massey333, If you look again your p/n is for the
3 stage primary( 1006 543M91). Kyle needs for the
2 stage. Chuck
massey333
03-16-2008 09:57:37
 Re: Massey Harris 55 diesel primary fuel filter???? in reply to chuck bergstrom, 03-15-2008 12:19:25
I won't agrue the point with you,because the only reason I posted was your P?N doesn't show up in any Massey parts books from the 50s and the numbers I gave are the only one we have ever used regardless of 2 or 3 Filter systems.So I will summit to your knowledge and call it quits.
chuck bergstrom
03-13-2008 08:46:16
Kyle, On The Bosch APE 2 stage filter set up the
primary(small)filter is Massey p/n 1000966M91.
There are 9 of these in Chilton,Wi. Must be ordered thru (any) implement dealer. Call THE
PARTS DEPOT 1-800-743-3768 if you don't have a
regular dealer that you use and they can recomm.
one. They give great service-ship same day. Chuck
El Toro
03-13-2008 03:59:55
Call 1-800-233-6539 and see if they have a filter for that Continental J382 engine. Hal
