Oil Change After Engine Rebuld
Tom from Buckey
03-12-2008 05:53:11
I completely rebuilt the engine in my 150 Gas, Z145. Sleeve kit, bearings, valve springs, valves, valve seats. I have around 24 hrs on the rebuild and using no oil. I haven't done any heavy work with it. Just a few post holes and grading drive with box blade. A lot of the hours are just driving the tractor at low and high RPM's.
Question: When should I change the oil and filter?
51Pony
03-13-2008 15:12:35
 Re: Oil Change After Engine Rebuld in reply to Tom from Buckeye Lake, 03-12-2008 05:53:11
Tom,
When my Dad used to rebuild an engine, He'd put it outside with a piece of cardboard covering most of the radiator to make it run hot, then run it at high RPM for 3-4 hours. Change the oil, then baby it for another 40 hours and change the oil again. He worked for an International dealer for many years.
Dale in WV
03-12-2008 12:11:24
My rebuild shop told me to change oil after 40 hours. Like MF Poor said, lots of responses = lots of different replies.
MH Poor
03-12-2008 07:02:50
But then, if you 10 replys, you will get 10 different ideas. We are sooooo independent!
MH Poor
03-12-2008 07:00:36
I would change it now, and then again in another 100 hours. Then you should be good to go into your regular oil change cycle after that.
