MH22, MH33
Pete
12-26-2000 14:33:48
Again, MH is not my area of expertise so a little help is needed. I just ran accross 2 MH's which I can get reasonable, 1st is a 22 std in pretty good original condition, complete, new rubber, pto but no hydraulics, the other is a 33 wide front with 3pt, complete but definately in need of more work than the 22. Question is; is there any market out there for a decent 22 std? Since the 33 floats my boat more, my idea is to finance some 33 parts with profit from the 22, problem is, you can't hardle give Massey Harris's away in my area of upstate NY. Thanx, Pete
BlueLight
12-27-2000 09:42:01
 Re: MH22, MH33 in reply to Pete, 12-26-2000 14:33:48
I agree with Alberta Mike on workability.
You are in the ideal state if you want to purchase
a MH. Ontario's back country is strewn with
MH parts and you shouldn't have any problem getting parts. MF dealers (village dealers)
still carry the parts and Ford Tractor dealers
still carry carb kits. Clutch parts are still
available. My MF dealer will do a complete engine
job with no hassles.
The MH's usually have less value than (x)N
series of ford tractors in this area. Having 2
MH30's, turned out OK for me and except for rims
had no problem finding parts. I found out it's
better to have 2 MH's of the same model.
I would make a list of everything molded on
your tractor, ie:rims, distributer cap, governors, water pumps, etc and just ask around to see if
you can get parts, if you can, go for it. Parts like rads you can find an alternative.
Someone told me that the transmissions on
the MH of the 50's were mostly interchangable
between models, that's another plus if true. You might find other parts you can swap with your other tractor as well.
Any MH with 3PH will have more value than a
straight puller. Ford's have more value, but I
find the MH's relatively stronger.
Alberta Mike
12-26-2000 17:42:08
Pete: If you can't give MH's away in your part of the country, then of course you are going to have to think of dealing it elsewhere. Mind you with the cost of shipping tractors, this makes tractors far away less appealing to the buyer. I do know that up here (Alberta, Canada) MH's are no different than any other brand, somebody out there wants them eventually. I guess a guy just has to gamble that he can come out on the good end of any and all deals that he pulls off. I would think the 22 might be a little more collectable from a collector's standpoint, but the 33 more desireable for someone who wants to work it. See ya.
