MF 25,
Pete
12-26-2000 14:26:48
Guys, Am branching into Masseys, an area I'm not to familiar with, 1st is a MF 25 Diesel Deluxe, and it is a project; needs engine rebuild, tranny, pretty much everything as it has been sitting in a hedge row with the oil pan off due to a spun bearing, for 12-15 years. But...sheet metal is good and tractor is complete so I'm gonna go for it. I have a very good Perkins engine dealer local so engine hopefully won't be a problem, as I live in upstate NY where MF is not that popular, I have yet to find a dealer who even admits that he has heard of this model, let alone get me parts. After market parts are apparently not available...What part problems will I run into? Any dealers who cpuld help? Thanx, Pete
LANCE
01-06-2001 20:31:23
 Re: MF 25, in reply to Pete, 12-26-2000 14:26:48
THE MF 25 IS A FRENCE BUILT TRACTOR.THE MF130 WAS THE NEWER MODEL.ONE SUGESTION I HAVE IS WHEN YOU OVERHAUL ENGINE IS TO PUT TRACTOR UNDER A LOAD I LIKE TO RUN THE FIRST HOUR AT ABOUT 25% LOAD AND GO TO 50% LOAD FOR ONE HOUR AND THEN 75% FOR ONE HOUR .AFTER THIS YOU SHOULD BE ABLE TO USE NORMAL .DURING THIS BREAKIN PERIOD VARY THE ENGINE RPMS AS MUCH AS POSIBLE.THIS SHOULD HELP SET THE PISTON RINGS WICH IS A PROBLEM WITH THIS ENGINE.GOOD LUCK LANCE
