MF 65 Carrier Bearing
RichardR
03-10-2008 19:21:44
Help!! I removed the left axle to replace the brake discs and discovered that the seal was leaking. The big problem though is that the carrier bearing was badly pitted. I think that I have found the correct parts here and on another website, but can't figure out how to pull the bearing cup (race) out of the housing. Any advice or observations would be greatly appreciated. Thanks
RichardR
03-13-2008 18:20:37
 Re: MF 65 Carrier Bearing in reply to RichardR, 03-10-2008 19:21:44
I got it all back together today. I made a couple of makeshift pullers for the cup and cone and got them both removed after much work. The new parts came today (I ordered them the day before yesterday). Just used a brass punch and a hammer to re-install. Put in the new brakes and oil seal and everything is back together. Thanks for the help. It's nice to have a site like this where you feel like you have some backup.
Aaron Ford
03-12-2008 21:05:10
I'll be darned, here I was reading y'alls posts and there was my name...
Yup, been there. I recall that I did it the hard way, heating and beating the thing out with a slide hammer.
My neighbor showed me a quick way. You weld a bead inside the race all the way around. Make sure the ends of the weld are connected. Now sit back and wait. It will fall out on its own when it cools. If I recall correctly, the bearing is on the plate and it was quite nasty to remove as well. I believe it came off with incrementally larger chisels used as wedges working around the bearing. Reinstall required the use of an oven and a freezer.
I have my tractor set on a pretty steep hill and a fella stopped by to look at it. I knocked the shifters into neutral and fired it up. The brake was set so it wasn't going anywhere. It was obvious from everyone there that I was the only one in attendance that trusted the brakes. They hold tight.
As I found the same thing, I tore into the other side immediately. The right bearing was in better shape than the left, but still bore replacing. I was there already and all. Also if you pull into the right side, you can pull the carrier and clean up all that crud under the pto and diffy.
Hope your project goes well. Fire me an email if you cannot get it out and I will try to dig up pics of my project.
Aaron
RichardR
03-13-2008 06:13:35
 Re: MF 65 Carrier Bearing in reply to Aaron Ford, 03-12-2008 21:05:10
Thanks, Aaron and Eric. I have made some progress and will describe what I have done when I get a little more time.
Richard
Eric in IL
03-10-2008 19:45:09
Well if you are working on the left axle you can remove the whole differential from that side. It will just slide out, might be a tad heavy . Then you can use a slide hammer puller on it or take it to a shop that has one if you don't.
I think Aaron Ford from this board has been through this bearing replacement on his tractor. Maybe he'll chime in.
