65 rear rims
prnstr
03-09-2008 18:44:24
Can I use something other than the adjustable style rims I have on my 65??? I see that they`re so much more than a regular rim. If I was to go with a standerd rim style, what hoops would I have to jump through to get it to bolt up?
Fred T. Hart Jr.
03-09-2008 19:59:07
 Re: 65 rear rims in reply to prnstr, 03-09-2008 18:44:24
do you currently have a set of adjustable rims for the tractor?, If so, they sure are nice if you were to ever want to adjust rear wheel width.
If rusted through and not repairable, I guess std. rims were available for this tractor.
However, would appear that outer rim replacement would be less than replacing the whole wheel as you would have to do if you placed non adjusting wheels on the tractor.
prnstr
03-10-2008 16:19:48
 Re: 65 rear rims in reply to Fred T. Hart Jr., 03-09-2008 19:59:07
My adjustable rims are rotten around the valve stems. So would i be able to make standard rims work or do I have to change the centers out???
Eric in IL
03-11-2008 08:02:31
 Re: 65 rear rims in reply to prnstr, 03-10-2008 16:19:48
If you don't want to go the cheapest route, by fixing your existing rims, check on rims for the industrial version of the 65. I am not sure of the model number but 3165 sticks in my mind, but that may be the industrial equivalent of a 165. Non-adjustable rims from it would also probably fit.
prnstr
03-10-2008 14:05:00
Dave Sherburne NY
03-10-2008 15:33:31
 Re: 65 rear rims in reply to prnstr, 03-10-2008 14:05:00
If the only bad spots are around the valve stem,
remove the tire and tube, drill a new hole for the valve stem about opposite the bad whole, and have
the bad spot cut out and and a new piece welded in. I've done this on more than one wheel.
RichardR
03-12-2008 18:15:44
 Re: 65 rear rims in reply to Dave Sherburne NY, 03-10-2008 15:33:31
Good idea, Dave. I'll have to try that on one of my fronts.
