Massy Ferguson 165
pidgeon toed
03-06-2008 16:14:38
My brother has a MF 165 and it needs brakes. My question is how does that happen ? Looks to me like the rear wheels and the axle housings have to be removed and the brakes are right up next to the rear housing. Which looks like a rather envolved process. We have the tools including an engine hoist to lift the wheels etc but was hoping maybe there was a simpler way of doing things. Your input is much appreciated.
Bob
DavidP, South Wales
03-07-2008 00:11:15
 Re: Massy Ferguson 165 in reply to pidgeon toed, 03-06-2008 16:14:38
Hi,
The world would be a wonderful place if there was a really 'simple' way of doing things..... ..and engineers would be out of business!!
First of all have you adjusted the brakes? Is it a case of having pedal pressure but no braking effort? Is yours a dry or wet brake tractor. In the UK tractors after about 1971 were all wet brake. This can be checked by looking at the axle housings just below where the top link is attached. If its a wet brake you should see 5 notches in the outside of the axle housing face each side. If you have to remove the housings it is a straight forward job done with care. If you have an engine hoist you are half way there. Inside as well as the discs and actuator you will find seals which should be replaced. If it is a dry brake model do you have any signs of the brakes 'grabbing' or jamming on? If so this is usually wear in the actuators and replacement is recommended. Expensive but worthwhile.
DavidP, South Wales
