Mf 240 Lift arms will not lower on their own.
Robert in Md
03-03-2008 19:56:56
My Mf 240 Hydralic work fine with heavy equipment but with light equipment the lift arms will not lower on their own . I have to stand on the arms and jump up and down to get them to drop. I drained the oil today and cleaned the filter, what do I need to do to correct this problem before adding new oil. Someone said to take the right side plate off and do something. I need some directions and help. Thanks Robert in Md.
DavidP, South Wales
03-04-2008 00:13:56
 Re: Mf 240 Lift arms will not lower on their own. in reply to Robert in Md, 03-03-2008 19:56:56
Hi Robert,
Have you checked the position of the RESPONSE CONTROL lever on the RH round side cover?
If this is set to the 'SLOW' position you may well have to "jump on the arms".
If operating it makes no difference set the oil level to that of the bottom bolt and remove the cover. Operate the lever inside manually but be prepared for the arms to drop suddenly if you have something heavy attached. If this works OK check the connecting linkage.
DavidP, South Wales
