MF 670 Lift Problem
Ron Nickels
03-01-2008 18:44:23
MF 670 lift started acting up . Lift would go down with tractor operating faster than idle, then when you idle it down the lift would come back up. Now the lift will not come up at all. The hyd. for the loader still work okay. Anyone have a clue as to what is wrong. Also, the hyd. filter light is on but I just put a new filter and oil in it less than 10 hours use ago. HELP!!
Don Snyder
03-02-2008 18:41:43
 Re: MF 670 Lift Problem in reply to Ron Nickels, 03-01-2008 18:44:23
If this problem came after you changed the oil and filter i would check the filter out to be sure it is the correct filter. Don Snyder
