MF65 hydraulic remote
weve in pa
02-29-2008 15:11:54
I have a MF 65 1963 diesel it has a duel remote it looks like the one in the owners manuel. i was wondering what the knob at the rear of the remote dose? the owners manuel dose not say. I have a loader hooked up dose not seem to make a
differnce if it is screwed in or out. the loader works thanks
Don_G
03-01-2008 04:21:57
 Re: MF65 hydraulic remote in reply to weve in pa, 02-29-2008 15:11:54
Hi
The valve will only affect the lift side of the cylinder that is attached to that lift port. Your loader lift may be on the other port.
Don
Don_G
02-29-2008 16:35:43
The knob is called the Lock Out and Variable Drop Cartridge. It is an optional accessory. It is used mainly to control implement cylinders.
You can use the knob to control the rate of implement drop. You turn the knob all the way in for a fast unrestricted rate of drop. Turning the knob out progressively slows down the rate of implement drop. When the knob is all the way out the implement will not drop.
The cartridge also serves as a check valve on the lift side to provide a positive means of maintaining cylinder position.
Don
weve in pa
02-29-2008 17:42:43
 Re: MF65 hydraulic remote in reply to Don_G, 02-29-2008 16:35:43
Thanks 4 the respons. I think i had it all the way out and the loader still droped. i will check it tomrrow as it has been snowing for 9hrs and dosent look like its going to stop any time soon so i will get a couple hrs clearing my lane.
