TO35 vs 135
Woodchopper
02-29-2008 06:12:24
What is the difference between a TO 35 and a 135?Thanks, Dennis
Gerald J.
02-29-2008 09:33:23
 Re: TO35 vs 135 in reply to Woodchopper, 02-29-2008 06:12:24
Lots different tin work.
More transmission options. Bigger engines.
The Perkins diesels are different. One indirect, the other direct injection. I don't know that the TO-35 ever got a Standard gas or diesel engine, those were in earlier TE and TEA models as far as I know.
Gas engines in the 135 are larger, but two options. The Special (stripped model) used a Z-134 Continental, the Deluxe used a Z-145. The gas engine in the TO-35 was never bigger than the Z-134. Mid years of 135 production use a Perkins gas engine in place of the Continentals.
The 135 has more seat options. And probably weighs a bit more for better traction. And is as much as 20 years younger. Many more 135 had the power steering option.
Gerald J.
MF Poor
02-29-2008 06:24:20
Improvements in the hydraulic system, primarily draft and position control. More options as far as seats, fenders, lighting, and instrumentation.
Jerry/MT
02-29-2008 07:43:01
 Re: TO35 vs 135 in reply to MF Poor, 02-29-2008 06:24:20
Aren"t the engines different? I think the TO-35 diesel is a Standard Diesel and the 135 uses a Perkins diesel. Not sure about the gas versions. The T0-35 used the Continental Z134 I believe.
MF Poor
02-29-2008 07:48:31
 Re: TO35 vs 135 in reply to Jerry/MT, 02-29-2008 07:43:01
I'm sort of lumping the TO-35 and the MF35 together. The MF 35 had the Perkins diesel as well as the 135. Continental Z134 4-cylinder gas in all three until 135's finally got a Perkins 3-cylinder gas later on.
135's got updated sevceral times as time went along. (ie pressure control, alternators, ect)
Fred T. Hart Jr.
03-02-2008 15:45:08
 Re: TO35 vs 135 in reply to MF Poor, 02-29-2008 07:48:31
I have driven both models and am not sure that each model change between the tractors was an improvement.
The gear shift levers are longer on the TO, therefore it easier to shift.
TO does not have as much power as 135, but TO has a Continental Z134 engine that was a great little engine, if well cared for. The 135 3 cyl gas Perkins seams to shake and have not heard alot good about them.
I understand both TO and 135 had Perkins diesel engines, good engines but harder to start in winter.
last model 135 diesels had almost 35-37 hp.
Buy what you get the best deal on: Remember, if you get one with Multi power, TO or 135 plan on having multi power rebuilt, about 1K.
Good Luck,
