MF 232 LOADER HOW TO ATTACH TO MY MF231
organic
02-27-2008 07:17:27
I just bought a used 232 loader for my Massey Ferguson 231 tractor and I need some information on how to best attach it to my tractor. ant info will be greatly appreciated.
[email protected]
TEXAS TIM
02-28-2008 21:44:44
 Re: MF 232 LOADER HOW TO ATTACH TO MY MF231 in reply to organic, 02-27-2008 07:17:27
sir it should have came with mounting brackets for your tractor . the brackets should attach at the bell housing of the trans and the front of tractor . the plumbing can be used with a front pump mounted to the front of crank shaft . or you can get a switch block for the lift top which will allow you to use the internal lift pump of the three point . you can also use the hydro coupler remotes on the back of tractor if yours have them . if you do not have the correct brackets and the ones you have are to difficult to adapt you can obtain them from a massey dealer .
495man
02-27-2008 13:50:22
 Re: MF 232 LOADER HOW TO ATTACH TO MY MF231 in reply to Jeff-oh, 02-27-2008 07:17:27
Haven't been around them, but I understand that you may want a PTO or crank drive hydraulic pump to get any sort of satisfaction using the loader once it's on the tractor.
Not sure what came with your loader.
ORGANIC
02-29-2008 10:59:09
 Re: MF 232 LOADER HOW TO ATTACH TO MY MF231 in reply to 495man, 02-27-2008 13:50:22
THANKS FOR THE REPLY. I HAVE 2 BRACKETS WITH 4 HOLES EACH AND MY TRACTOR HAS REAR HYDRO CONNECTS WITH A VALVE BLOCK.
