Massey 3650
Shawn Gardner
02-26-2008 15:28:54
I"m having trouble with with the cluth on my Massey 3650. it feels like I have no clutch. Could anyone give me an idea what could be the problem.
richardinnz
02-26-2008 21:08:50
 Re: Massey 3650 in reply to Shawn Gardner, 02-26-2008 15:28:54
You wont find a resivioir because the clutch and brakes are fed from the main hydraulic system. Remove the inspection plate and look up in to the clutch housing to check if the seals have failed on the hydraulic release bearing. Get an assistant to operate the pedal as you look.
marlowe
02-26-2008 15:33:47
i think that it is a hyd. clutch and you are out of fluid look for a little brake reservoir and check it
Shawn Gardner
02-26-2008 16:42:53
 Re: Massey 3650 in reply to marlowe, 02-26-2008 15:33:47
Yes it is a hydraulic clutch but I only find one place to add hydraulic oil and that is in the main hydraulic reservoir. Ive been all through my operators manual and I don't find another hydraulic reservoir on this tractor. Right now I don't have brakes or a clutch which accoring to my manual are part of the second stage hydraulics. Please advise I'm still lost here.
marlowe
02-26-2008 18:14:16
 Re: Massey 3650 in reply to Shawn Gardner, 02-26-2008 16:42:53
never worked on a 3650 but have on older ones and they all take brake fluid. the linkage should lead you to the reservoir sorry i can't be more help but don't get in to that new of stuff
Geoff in Scotland
02-27-2008 04:18:01
 Re: Massey 3650 in reply to marlowe, 02-26-2008 18:14:16
There is definately NO hydraulic brake fluid on any 1000 or 3600 series....as stated the fluid comes from the tractor hydraulic system....there are 2 types of clutches....one is a push type telease system while the other one is a pull type system....best idea is to get someone to operate the clutch and watch what happens....the seals in the release cylinder (or tandem cylinders in some cases) can leak internally with no outward signs of oil leaks...either way it means splitting the tractor and renewing the seals and bleeding the brakes and clutch when assembled....if it is a pull type clutch you will need to remove the large clip inside that connects the clutch to the release cylinder
Shawn Gardner
02-27-2008 17:48:12
 Re: Massey 3650 in reply to Geoff in Scotland, 02-27-2008 04:18:01
thanks I will try that.
