Massey 3165 Backhoe
Ed in Rock Cree
02-26-2008 15:28:52
I would like to remove the backhoe attachment &
use the 3 point & pto.
At this point the 3 point will not raise or lower.
Is there a 3 point cut off valve or does the backhoe have to be off before the 3 point will work ?
Thanks for any help
Ed
Ed in Rock Creek
02-28-2008 09:33:55
 Re: Massey 3165 Backhoe in reply to Ed in Rock Creek, 02-26-2008 15:28:52
Thanks for all the advice.
I will try to free it up this weekend.
Ed
Vapet
02-27-2008 07:12:24
Does your machine have the lift arms on it with the backhoe also mounted? I have a MF 40 and can only have one or the other. Or do you have a 3pt mounted backhoe?
Ed in Rock Creek
02-27-2008 09:43:26
 Re: Massey 3165 Backhoe in reply to Vapet, 02-27-2008 07:12:24
The backhoe model 185 is frame mounted with pins.
The 3 point arms are on the tractor in their
highest position.
Vapet
02-27-2008 11:17:04
 Re: Massey 3165 Backhoe in reply to Ed in Rock Creek, 02-27-2008 09:43:26
Have you placed both lift levers in the down position? Is there room for the lift arms to go down? If not remove pins from rockshalf arms and try to pry rockshalf arms down. Thought my lift didn't work, didn't have rockshalf arms on just the lift shalf with pipe type covers bolted on. Removed the covers and forced the shalf to rotate down and then it worked. Hope yours is as simple as this.
Ed in Rock Creek
03-03-2008 15:41:40
 Re: Massey 3165 Backhoe in reply to Vapet, 02-27-2008 11:17:04
I was able to move the 3 point arms down with the tractor not running.
When the tractor was started the arms moved back
up even though the controls were down.
I removed the right side plate & the up & down
lever travel seems to be ok.
It looks like Don is correct that the pump is
stuck in the highest position.
Any more advice?
Ed
Don Snyder
02-26-2008 18:47:35
Most likley the control valve is stuck in the hydrulic pump from not being used for a long period of time. Don Snyder
