Massey 135 - Diesel (general thoughts)
Stones Throw Fa
02-26-2008 11:35:04
Hi All...
Our search for a versatile farm tractor; bush-hog, field cultivator, disc., transplanter, rotovator....
Has lead us to consider a number of different tractors. We recently looked at a Massey 135 Diesel. It seemed to be in really nice running condition.
I"m curious what folks thoughts/experiences with these tractors are?!? (either in general or per our intended use"s)
Are there particular areas of concern - etc.
Any thoughts/info much appreciated!
Brian
Finn Md
02-27-2008 09:41:18
 Re: Massey 135 - Diesel (general thoughts) in reply to Stones Throw Farmer, 02-26-2008 11:35:04
I've had a 135 D for years - excellent tractor. They work well with a 5-ft rotary cutter (bush hog). If you're going to do much plowing or other heavy soil engaging work or hay baling you may also consider a MF 165 or 175. Similar price to a 135 but more power and weight. The 200 series MF's are also excellent if you can find a 245 or 255, which have better brakes (wet brake models)and hydraulics. Like others have said, check Big Deans website for things to check out. Good Luck
Frema
02-27-2008 03:41:03
Howdy
Like the others stated - A true friend. I`ve had mine for 25 yrs. with full tillage of well over 10 acres, and by now she`s over 6000 hrs. and still fit as a fiddle.
Go`n get it.
Frema.Dk.
36 coupe
02-27-2008 03:33:25
Ive used one to bale my hay when my Ford lost the upper bearing in the steering.Nice tractor,Id buy one myself in a minute.
richardinnz
02-26-2008 21:10:58
Get one!
JAT
02-26-2008 16:38:37
Never had a 135 but grew up with a MF 35 and all the above comments applies to it as well. We had a hill behind the barn and the 35 would haul a loaded manure spreader up over the hill in high gear whereas our MF150 had to be geared down to 4th to go over the hill with the same size load.
Brian Hewlett
02-26-2008 13:51:16
You will not go wrong buying a Massey 135! These are one of the best tractors ever built. I have a little grey hair and have owned one all my life. In the farming area I am in, these tractors have been popular and have a very good reputation. The Perkins engine is tough and easy to rebuild if necessary.
Brian
MurrayE
02-26-2008 12:33:41
These are a nice tractor. I have owneed a 135 MF //3 cyl perkins for about 5 years. Mine is used mostly for hauling a few cords of wood, planting a garden and for snow plowing and grading the driveway. It is almost in retirement.
I really enjoy using the tractor and can spend hours working on odd jobs. Definitely a good investment for me and the resale value appears to hold or increase. You really can't lose if you purchase one of these tractors. Cheers, Murray
Gerald J.
02-26-2008 12:04:36
I've owned a MF-135 gas (continental) for 20 years. Farmed 25 acres of hay and row crops, full tillage. It came with a MF-236 loader that was too much for the size of the tractor.
Mine has 6 speeds in the transmission plus multipower to make it 12 speeds foward. Enough for most jobs, though the multipower is reputed to be less tough than the other gears in the transmission.
The input shafts for the transmission are concntric for drive and for PTO and the seals there do wear and it takes a split and some machine work building up worn shafts to make the replacement seals work.
Some people have troubles with the tachometer drive from the Perkins engine leaking oil.
There were many MF-135 made so aftermarket parts abound and there are imitations still made in India.
I've seen few complaints about the Perkins engines, though at age 40 years it is possible to have worn one out.
I don't have a brush hog, but I do have a 6' 3" JD flail mower I use with mine. Also a 12' field cultivator and a 6' offset disk. I pulled 2x 16 moldboard plow. Rotovator, be sure it will go slow enough at PTO speed. Mine just goes down to 1.5 mph and some rotovators want 3/4 mph. I've mowed many acre of hood high hay with a 9' 3" sickle type mower/conditioner at speeds up to 6 mph.
I've had to rebuild the power steering cylinder, but a good machine shop charged $125 while the local MF shop wanted $500 for the assmbly.
There are way fewer handy MF dealers than there were around here 20 years ago, so it takes long distance pphone calls and some running around to get genuine MF parts these days.
Many potential owners pass up gas models for the economy and perceived longevity of the diesel model. Don't know, never owned any diesel and I know how to tune a gas engine.
Gerald J.
MF Poor
02-26-2008 12:01:55
Pound for pound, dollar for dollar, the best tractor ever built. Well balanced, good power to weight ratio, simple and reliable. Parts are still VERY easy to come by, be that OEM or aftermarket. Built to be worked on by average mechanics out under the shadetree in the barnyard. A handfull of basic tools and the manuals and you can do most anything there is to do on these tractors. The Perkins AD3-152 is a fuel mizer. Take proper care of it and expect a LONG lifetime of dependable use. They'll cold start in the worst weather.
Look on BIG DEAN Austins website for all the mechanical items to check. Order his CD on maint. and repairs of 100 series and you'll be money ahead.
Lou
02-26-2008 11:47:42
If it has a 3 cylender perkins buy it.IMHO
Wesley Stephens
02-26-2008 15:24:50
 Re: Massey 135 - Diesel (general thoughts) in reply to Lou, 02-26-2008 11:47:42
We have one that has been on our farm for over 40 years. It is a great tractor that gets used a lot and gives very little trouble. These tractors, along with offset Farmalls and 2000 and 3000 Fords area very popular in this area for pulling tobacco sprayers and drags. I"m going to put ours to use growing tobacco this year for the first time since the 70"s.
DavidP, South Wales
02-26-2008 15:24:05
Hi,
Had my 1965 diesel 32 years..... absolute cracker!!!!! !!
