Hello Everybody, I got a bunch of quality responses from the last post asking whether the 65 is a good tractor. Everything sounded positive, so I went and took a look. Now I will let you all know what I found, and get some opinions. Please tell me what you know about the serial number, how many horsepower and year especially. The numbers on the cast bell housing and case are included but probably mean nothing for this discussion.SNM 676833 Case # 183253m5 Bell #182840m2 Does this have an external hydraulic pump? I forgot to look. Here are the major drawbacks. They did not volunteer to move the tractor, so I am assuming that the clutch is good. The drawbar did not go up or down, they did not know what levers exactly were supposed to be used for this. The tractor has been sitting for the better part of 15 years they say. There was a point that the tractor was shut off, when turned back on, the drawbar quickly raised the five or so inches it had fallen. Other than that, there was no moving it(we never got to put the weight of an implement on it). The loader cannot get out of its own way. It did not even try at all to lift the tractor and moved super slow. The power steering did not function at all when the tractor stood in one spot. When I tried to move the steering wheel, it felt as if it mechanically bound at the bottom of the steering shaft, although someone claimed the problem was with the pump. I don't know. I know I never saw the wheels turn at all. The hour meter said 1750, however I did not look to see if it was working. The upsides are that it seemed to run real well, with no smoking at all. It sounded real good also. There were no real visible leaks anywhere, to include the bell housing cotter pin hole. This seems like a possible good candidate to try to buy right and fix. Thats what I think, but what do the people here think? What might be a good price with the above problems? Does need a bit of tin, not alot though. Now that was an essay, hopefully some of you stuck through 'til the end. Tell me if I am a fool now..... . Brian
