massey 35 lift system
Terry Miller
02-23-2008 15:26:12
Last fall we restored our 35 Deluxe. After completing and assembling, we have no lift on the 3 pt. The fluid is full, and I have removed the two side plates on either side of the tractor. It does aux hydrdraulics. I am no hydraulic mechanic and have no idea what to do next. I can see the vertical levers on the right side as seated but they do not move. It does not appear that the pump is spraying or leaking, but again I may be not looking in the right location. Can anyone help? Terry
Dean
02-24-2008 05:20:17
 Re: massey 35 lift system in reply to Terry Miller, 02-23-2008 15:26:12
Terry:
I assume you mean it has aux hydraulics.
If so, depending upon the type fo remote hydraulic valve that you have, it may be positioned into the remote position. If so, all of the oil will be directed to the remote outlets rather than the lift.
Dean
Glenn R
02-23-2008 18:45:01
Did you check to make sure the o rings on the stand pipe that run from your hydraulic pump up to your top cover aren't bypassing losing hydraulic pressure. With the side covers off lift your hydraulic contols up and down and check to make sure the fingers are moving back and forth allowing the pump to open up. I had my top cover off and when reinstalling the fingers didn't fall back into the proper place and I had no hydraulic pressure until I realigned them properly.
Terry Miller
02-24-2008 05:21:13
 Re: massey 35 lift system in reply to Glenn R, 02-23-2008 18:45:01
Glen can you call me cell? I am a little unclear as to what you mean exactlly. Terry 715-559-4337
I will gladly call you back.
