Rattle in hyd. 135
Frema.Dk
02-21-2008 10:06:08
To DavidP.
Last weekend I asked how to get rid of the rattle, and you suggested the pressure control to be the problem. I had the right sidecover off, and worked with the knurled screw for the diaphragm. I had it 3 turns inwards, and the arm started oscillating - then outwards until osc. was a minimum. I had the gauge on and the pressure was 10 bars above the 178 - I didn`t lower, and the rattle was indeed reduced. This day it caught me that I didn`t loosen and fasten the square screw for the response. Instead of using .25" from the top I set it at .75" - mostly because the lowering speed then would be easier to control. The short story is that now the rattle is almost gone with the weight of a 2# plow. I looked at the pump through a mirror, and I think it was quite still, so that it wouldn`t be the cause
I now think that you gave the right solution - Thanks a lot.
Frema.Dk
DavidP, South Wales
02-21-2008 23:54:26
 Re: Rattle in hyd. 135 in reply to Frema.Dk, 02-21-2008 10:06:08
Hi Frema,
Bit of a difficult one to get right without seeing the tractor but very glad to hear that it has certainly improved the situation.
David
