MF Super 90 serial #
Rex Williams
02-18-2008 14:04:46
I just bought this Super 90 and would appreciate knowing where the serial # is located so I can determine the year it was made.
Thanks,
Rex
730virgil
02-19-2008 09:50:07
 Re: MF Super 90 serial # in reply to Rex Williams, 02-18-2008 14:04:46
i once worked tfor a man that liked his masseys
he had only 1 that was any good that was a super 90
Swede in IOWA
02-18-2008 17:22:59
Serial number plate is attached to the battery box plate on the right hand side of the tractor.
Rex Williams
02-19-2008 07:32:54
 Re: MF Super 90 serial # in reply to Swede in IOWA, 02-18-2008 17:22:59
Thanks for your help.
I am looking forward to spring when I can spend some time with the tractor. There are numerous adjustments for the hydralics which I will have to try and get set right. The PTO and hydrallic levers mounted on the fender seem to be out of adjustment. The previous owner has screwed in some and screwed out some. I have ordered a manual. Maybe it will help. Are you familiar with how to correctly set these?
Thanks,
Rex
