MH 30 Camshaft Gear wanted
NoContest
02-17-2008 04:33:41
I recently had a break down with my 1950 MH30. After going through the typical diagnostics, I ran a compression check to see all cylinders around 40psi- I then pulled the front cover off to find that the camshaft gear key had slipped on the gear, chewing up the gear slot. I found the camshaft bolt on the botton of the front cover. I need a camshaft gear F400H-401 anybody got one of these critters? Also- the camshaft thrustplate is not bolted- is this correct?
El Toro
02-17-2008 07:22:02
 Re: MH 30 Camshaft Gear wanted in reply to NoContest, 02-17-2008 04:33:41
Try this number 1-800-922-5632 for your 162cid
Continental engine to see if they have a new camgear. Hal
Jeff Z.
02-17-2008 07:13:28
MH 30 Parts
http://www.mainetractors.com/massey_harris_30/massey_harris_30.html
NoContest
02-17-2008 04:37:07
I see I stated I found the camshaft "bolt" that should have said camshaft "nut"
old
02-17-2008 08:27:22
 Re: MH 30 Camshaft Gear wanted in reply to NoContest, 02-17-2008 04:37:07
I have an almost complete MH30 engine laying in my shop. About all that is missing is #2 piston which went some place but not sure where. It disappeared when the engine was running and when I pulled the head all that was in that cylinder was the waist pin and rod but the piston was gone.
