Diesel leaking into oil?
jim Nielsen
12-17-2000 02:51:47
Hi, Ive a MF 185 (just like a 165 but with a slightly bigger engine). I know i filled the oil just to the top of the full mark on the dipstick, but now there seems to be quite a lot more oil! Where could this have come from? I have a JD 2010 in which the diesel can leak from the injector pump into the crankcase. Can the CAV pump on the 185 do this as well.
Help! Jim.
George T.
12-20-2000 13:11:13
 Re: diesel leaking into oil? in reply to jim Nielsen, 12-17-2000 02:51:47
yes when I had my pump rebeilt thay told me to watch for this as some times thay mess up a seal when thay rebuild. check the oil presher see what it says.it cost me about $285.00 to have mine rebulit this spring
Tom Stinson
12-18-2000 13:10:08
To answer your question; Yes, the Cav pump will leak past the front seal into the gear cover and into the crankcase. If your tractor has a diaphram lift pump, check it also.
I bought a rebuilt pump and 4 nozzels to the tune of $660 for a 285 Massey, not long ago. Had to pull the pump and replace a brand new seal that was cut on installation. I still have it laying here on my desk as a reminder right now. D--n supplier {can we use names here?} wanted to charge me an additional $50 PLUS the seal to fix it, because they say new type fuels dry seals out. BS! I had the pump less than a year, and it nearly screwed up a fresh OH. To make a long story short, I took a Massey power steering seal, #833935M {i think} for less than 5 bucks and fixed it myself.
Tom S. in Tn.
charles.macleod-matthews
12-19-2000 07:14:00
 Re: Re: diesel leaking into oil? in reply to Tom Stinson, 12-18-2000 13:10:08
Had this problem on a 185 pump was overfuelling and diluting the oil till there was low pressure .Recalibration of pump solved all
Greg McKinney
12-19-2000 19:19:48
 Re: Re: Re: diesel leaking into oil? in reply to charles.macleod-matthews, 12-19-2000 07:14:00
I agree with the first gentleman. Before I go and start pulling injector pumps, I'd first check that low pressure pump on the side of the block (I'm sure a 185 has one). They are cheap and easy to get to and can cause the same problem that you are describing. They get a hole worn in the diaphram and it sends the fuel under low pressure right through the hole in the side of the block and straight into your oil pan.
