Super 101 Brakes
Genos
02-16-2008 08:04:04
Have A 1940 Super 101, on the brakes, i have taken out all worn linkage slop, replaced linings, adjusted per manual, still pedal goes all the way down, it slowley stops but won't lock up wheel. if i adjust them to lock wheel and get some pedal their too tight and you can't turn wheel when jacked up. Any Ideas? Thanks!
Ed Marstellar
02-20-2008 13:30:20
 Re: Super 101 Brakes in reply to Genos, 02-16-2008 08:04:04
I have a 1938 101 and I believe the brakes are the same. I had to move the arm on the brake cam that the ends of the brake band go into to get the brakes to work and adjust correctly. If the arm on the cam has to travel too far the brakes don't work or release correctly.
