to 35
clint315
02-13-2008 14:39:28
myneighbor has a to 35 that i have done some work on for him. he lost the dipstick to the hyd system/rear end. the one by your right foot. are these avaliable?? or does any one know if one from a ford 8n would be the same?? im not too awful fimiluar with these brands but some of to series and fords look to be the same. thanks in advance
Rod in Smiths Falls, ON
02-14-2008 14:29:59
 Re: to 35 in reply to clint315, 02-13-2008 14:39:28
When I bought my 35 it had a small screwdriver in that spot as a dipstick. That left the transmission fluid a bit milky, so I changed it pretty quickly. The dealer had a new dip stick in stock at a good price.
Fred T. Hart Jr.
02-13-2008 22:35:30
when you get the dipstick replaced.
I drilled a small hole in top of dip stick handle, connected a small chain to dipstick and chained it to tractor.
When you get off tractor your shoe heal can catch the dipstick and pull it out, you never know it.
Good idea and you will solve this problem.
Jerry/MT
02-13-2008 17:28:02
I"ve seen them on ebay for around $5.95. If you can"t find one quickly, you can easily check for the correct oil level. Remove the lowest bolt in the access cover that the dip stick goes into. The oil level is correct when oil just starts to drip out of the lower bolt hole.
MF Poor
02-13-2008 14:46:03
Not sure if Ford dipstick is the same. In any event, the CORRECT ones are still available through AGCO/MF. Just bought one for a Ferguson F-40. (Same dipstick)
