MF 65 hydraulic pressure?
Tractor
12-16-2000 01:43:01
How much weight can the MF 65 hydraulics lift? or how much psi is available from the pump.
Thank you.
Pete Tatham
12-16-2000 13:16:25
 Re: MF 65 hydraulic pressure? in reply to Tractor, 12-16-2000 01:43:01
M.F 65 diesel,hydraulic lower arms will lift a max of 2500lbs from lowest position. Recommended max weight for field work and slow speed transport is 2600lbs. Recommended weight for road work in transport position is 1800lbs. Nominal setting of hydraulic system safety relif valve is 2500 lb/sq.in. Hope this is of help, Pete.
