Control Valve Seal...Tom Buckeye
finsrn
02-12-2008 18:14:19
Does anyone know what the seal number is for the steering control valve? I'm looking for a local replacement seal, not an Agco part number. I believe that Tom said he had the part number. I rebuilt mine and the Massey manual incorrectly states to put the seal in first and then the spool valve. Well, that don't work so I trashed the new seal after removing the spool after re-assembly, not that I could have removed and reused the seal anyways. I'm not sure how much longer my wife is gonna let me use the kitchen to work on this cylinder, it's about to whip me.
Tom from Buckeye Lake
02-13-2008 06:17:48
 Re: Control Valve Seal...Tom Buckeye in reply to finsrn, 02-12-2008 18:14:19
The seal that I used on my 150 is SKF 6741. SKF took over C/R a few years ago. I made a plate out of 1/4" steel to cover the pump hole so I could use the tractor untill the P/S was repaired. Steered OK if you are moveing.
finsrn
02-12-2008 18:16:07
P.S. This is a 1966 165.
