massyferguson/ no forward gear in trans.
dave@sekiushop
02-11-2008 11:49:15
model#mp300 ser#1196007604, 7" bucket&backhoe. I recently bought property and the tractor was thrown in as part of the shop. I repaired on leaking cylinder "seal" and drained all the transmission fluid,a lot of water came out of the system,refilled with type f fluid. and tried forward gear,it crept a little but did not go."reverse works good" what should i do next? split the case? "I already adjusted the linkage". Dave
Big Dean
02-11-2008 12:11:24
 Re: massyferguson/ no forward gear in trans. in reply to dave@sekiushop, 02-11-2008 11:49:15
Hi Dave I am assuming you have the Instant Reverse transmission with the forward and reverse pedals on the right side if you do you have either one or both seals and clutch discs bad in the forward clutch pack.email me if I can be of further help
