Massey Harris 44 wheel hub/axle
Marvin Hunt
12-14-2000 06:57:13
I'm swapping back tire/wheel/hub assemblies from a "doner" tractor to my running Massey Harris 44. I've been able to break lose the 4 lug bolts in the cast hubs with no real problem. However, the hubs are tightly seized to the axles. I've tried penetrating oil, propane torch, and rocking the assembly with no luck. How hard can you pound on those cast hubs before breaking them? Any suggestions for removing the assembly from the axels? Thanks!
JE
01-04-2001 18:55:13
 Re: Massey Harris 44 wheel hub/axle in reply to Marvin Hunt, 12-14-2000 06:57:13
I've got a 33 in my garage with the same problem. After trying a sledge, heat and a homemade puller I took time to look at it. It appears there is probably a key or keys in the keyway on the axel. I have tried to drive it out some, but can't tell which way it should go and don't want to really mess it up. Need to talk to someone or look in a parts manual to find out the answer....which I haven't got time to do yet. Good Luck!
