MF 255 Loose Fitting Sleeves
The Pennsylvani
02-07-2008 15:01:21
We have a 255 diesel with the Perkins 236 4 cyl engine in it and we ordered a Tisco piston & sleeve kit for it. Pulled out the old sleeves (they were really tough to pull out) and very lightly honed the block. Went to put in the new sleeves and they slide right in - you can turn 3 of the sleeves in the block but the forth one is tighter. Tried that one in another hole and appears that one sleeve fits tighter. Has anyone else experiened this type of a loose fit? Thanks.
Bob N.Y.
02-09-2008 16:22:45
 Re: MF 255 Loose Fitting Sleeves in reply to The Pennsylvanian, 02-07-2008 15:01:21
Are the old sleeves loose since you honed the block?
The Pennsylvanian
02-09-2008 17:19:08
 Re: MF 255 Loose Fitting Sleeves in reply to Bob N.Y., 02-09-2008 16:22:45
No - they won't go in, you would have to freeze them to get them back in. When we honed the block it was for only a few seconds and with oil to clean it up. Our dealer has ordered another set of sleeves for us to try. Remember one sleeve fits okay so the tolerance may be too wide on the others. If we get the others to fit a little tighter we are going yo use Loctite 620 on all of them too.
Danperkins
02-08-2008 17:44:28
You shouldn't have honed the cylinders, that could be the reason. The replacement sleeves aren't supposed to fit as tight as the OEM sleeves.
buford
02-07-2008 18:44:11
I wonder if you have a kit that might fit the Perkins 4/203 engine that was standard on early production models MF255, engine bore was a little less might be a good place to check I have done saveral Perkins engines and always set sleeves upright in freezer overnite then set sleeve in the bore, place a heavy piece of steel on top and with a 6 lb. hammer, with out any force drop hammer on steel, sleeves will slide on down you will do no damage at all. On old sleeves I never pull, I always break them and pull out from top just a thought These are tought little engines
marlowe
02-07-2008 18:10:50
also to in stall the right sleeves DO NOT pound on them they bust real EZ put them in the freezer over night and keep them real cold as you install them or they will not go in
Marlowe
02-07-2008 18:03:45
DO NOT use them sleeves ether your block has been reworked or the sleeves are wrong they should fit tighter then hel-
jonjon
02-07-2008 16:58:18
If the sleeves fit loose you could lose coolant into the oil.
Marlowe
02-07-2008 18:07:04
 Re: MF 255 Loose Fitting Sleeves in reply to jonjon, 02-07-2008 16:58:18
the 236 is a dry sleeve engine
El Toro
02-07-2008 15:59:04
I would measure the od of the old sleeves or have them measured and do the same thing to the new sleeves. With the sleeves being loose I would be afraid of the loose sleeves being pulled down by the new pistons and causing severe engine damage.
Your Perkins engine dealer may know what the bore should be and the outer diameter of the sleeves.
Federal Mogul would probably know this too if they made sleeves for MF tractors or for Perkin engines. Hal
