massey harris 22/ drive line
eric g in mn.
02-06-2008 18:01:31
my 22 vibrates when on high idle, i think it is a bearing in the input shaft, does anyone know where to find one of these if i need to replace it
Ian Johnsen
02-08-2008 21:02:32
 Re: massey harris 22/ drive line in reply to eric g in mn., 02-06-2008 18:01:31
You could have a bad u-joint on your driveshaft. you could have them replaced and have it balanced. You cold pull it from the clutch housing side and use it for leverage to check for play with your input shaft theory. Good luck.
