2745 clutch
Danperkins
02-06-2008 17:55:23
Are clutch alignment tools still readily available for the 2745 tractor. I need to split the tractor to change the rear main seal.
Danperkins
02-08-2008 17:49:15
 Re: 2745 clutch in reply to Danperkins, 02-06-2008 17:55:23
Thanks again for the info. I found one at a dealer that will loan it to me.
Marlowe
02-07-2008 18:22:13
you did not say you were changeing the clutch but i would and the last one i did the tool was with the clutch cheep plastic one clutch came from Napa
jogl
02-07-2008 17:43:42
I forget all the details, I also remember fretting about getting the transmission brake set up right. Too many years and not enough brain cells.
It might all come back to me soon, I just started into an engine rebuild and clutches on our 175 today.
JP.
Danperkins
02-07-2008 15:03:13
Thanks for the info. I do have a service manual and have read it through so hopefully I can get it apart correctly. Jogl, according to the manual, you have to disconnect the throwout release shafts when installing/removing the engine, so I don't see how you could have pushed the clutch in without those in place?
jogl
02-07-2008 04:29:18
When I did our 2705 I did not have an alignment tool so I used some appropriately sized sockets held together with ready rod and flat washers to make an alignment tool.
I was having a bear of a time getting her back together (the last half inch). I was almost ready to go beg borrow buy or have made an alignment tool when the wife came along. I had her hop into the cab and let in and out on the clutch pedal while I pushed and turned the fan belts and it popped right in. Just needed to move around a little bit for the splines to mesh up.
So I thought my home made alignment tool wasn't so bad after all, just need to keep thinking and have some patience.
I would second what Wayne said about the service manual. There is a lot of stuff to disconnect and reconnect on these 2700's when splitting, and a couple of tricky spots.
And BE CAREFUL!
Happy wrenching,
JP.
Wayne in Iowa
02-07-2008 02:29:55
The 2745 has two clutch discs,so better be able to borrow a splined clutch alighment tool from you local MF (AGCO) dealer. No offence,but if you have not split a 2000 series tractor before, you really should have a service manual, or get back for more information,
