Steering Turnbuckle Link
Steven, Avilla
02-04-2008 09:36:49
I'm rebuilding the steering cylinder on my 165 and I noticed the holes on the turnbuckle links appear to be worn. On Big Dean's CD he says that if the pins are worn at all they should be replaced. I'm assuming that goes for the links to? They are available from Agco but they cost around $20 each. Are they worth replacing?
DavidP, South Wales
02-04-2008 12:28:46
 Re: Steering Turnbuckle Link in reply to Steven, Avilla MO, 02-04-2008 09:36:49
Hello,
Absolutely!!! The whole system works on the basis that play in all parts is kept to an absolute minimum. Your initial movement of the steering wheel actuates the assistance. If this is lost you will have very much reduced steering assistance. Have an assistant operate the steering wheel and look for play in the whole system especially where the rod is anchored to the casting and sideways movement on the main shaft that goes through the casting as well. It is not normally necessary to replace all the parts. It is a lot cheaper to have all the holes drilled out to an available bolt/pin size and use those. Hole clearance must be absolute minimum. Make sure the bolts have plain shanks where they push and pull on the linkage.
If you can drill the bolts/pins and fit split pins, fine.
Do you know the adjustment procedure? If not, please come back and I'll take you through it.
DavidP, South Wales
