MF 35 Deluxe Deisel
Manny in CA
02-02-2008 18:52:22
I just became the owner of this deluxe 35. It has been setting for some time. It will not start. The engine does crank over but does not start. Not sure if it is getting any fuel. Glow plugs seem to be working. Any fixes? Also, the starter does not shut off when the ignition key is let go. Have to pull the cable off the battary to make it stop. Could it be the ignition key or the starter? Does any one know how the bleed the fuel system? Need your help!!
jogl
02-04-2008 03:01:03
 Re: MF 35 Deluxe Deisel in reply to Manny in CA, 02-02-2008 18:52:22
Spray the ether into the intake in small frequent squirts while you are turning her over. If you get too much in you'll know because the pre ignition of the ether will slow you starter right down.
I'm not sure about the starter, I'll have to check the nest time that I'm in the barn where we have our 35 wintered. On all of our other tractors the answer is yes, but the 35 is our oldest tractor so it could be different.
JP.
manny in ca
02-04-2008 11:13:25
 Re: MF 35 Deluxe Deisel in reply to jogl, 02-04-2008 03:01:03
Thanks JP. I'll wait to hear from you about the starter.
jogl
02-03-2008 05:49:00
If that is the Standard 4 cylinder diesel on that 35 you will almost certainly need to give it some ether to get it going. They are notoriously hard starters. Ours is an ether addict. And once it starts we have to keep giving it a little squirt for the first 15 or 20 seconds running.
When you crank it is there white smoke (unburned diesel)? If so try the ether.
As for the starter thing, sounds like you have it narrowed down. I would check / clean the solenoid first.
JP.
manny in ca
02-03-2008 10:19:56
 Re: MF 35 Deluxe Deisel in reply to jogl, 02-03-2008 05:49:00
Hi JP:
I"ll check for the white smoke. I"ll try the ether and where do you add the ether? Is it were the hose comes into the air cleaner? Can I take the solenoid off without pulling the starter?
Thanks for responding.
