MF 2200
Texas Denny
02-02-2008 12:59:45
A friend and I are looking at a disabled 2200 with a backhoe and a front end loader. It hasn't been used for a long time. Don't know the condition of anything - engine - transmission - hydraulics. All the parts are there except for the pads on the stabilizing arms. What would be a reasonable value for this be if the engine is a problem and if the engine isn't a problem.
135 Fan
02-02-2008 15:37:01
 Re: MF 2200 in reply to Texas Denny, 02-02-2008 12:59:45
If its been sitting for a long time, chances are it needs some serious work done to it. What does it look like? Abused, welded, covered with oil? Very hard to put a price on. If the loader cylinders aren't all rusted, the loader alone is worth something. Not running and decent looking enough, I'd say maybe $1500 or so but it's really hard to say. Dave
Texas Denny
02-02-2008 18:54:00
 Re: MF 2200 in reply to 135 Fan, 02-02-2008 15:37:01
Thanks, Dave. That is where we thought we'd start. The cylinders show no evidence of rust and there is paint everywhere - no rusted areas. Since the hood is off, we wonder about the engine.
Jack in NB
02-03-2008 04:31:28
 Re: MF 2200 in reply to Texas Denny, 02-02-2008 18:54:00
If the unit has the 3 or 4 cyl perkins diesel engine, the block isn't cracked, and the crank can be reground, you can overhaul completely for $500 - $600 parts. Probably the cheapest engines in the world to re-do.
I'd pull the plate off the side of the injector pump and take a look for rust or dirt. Normally they stay clean, and require no attention. If there's contamination in there, though, that can mean a rebuild or replacement, and that can run the bill up fast! Like $1000 - $1500!
Texas Denny
02-03-2008 05:30:49
 Re: MF 2200 in reply to Jack in NB, 02-03-2008 04:31:28
Thanks for the input.
