Massey 44 battery
lobelly95
02-02-2008 12:35:07
I have a 1951 Massey 44 that I am starting to work on. My question is what was the original battery set up? Right now it has a very large 6 volt battery (dead), however the cable has 2 battery connectors that suggests that it used to have 2 smaller 6 volt batteries wired (parallel?) together. Does that stay at 6 volt or does that change the voltage? What was original, and what are people doing now as an original and nonoriginal replacement? My father in-law said that had always been a hard starting tractor. I do plan on replacing the cables, wondering on any suggestions on that issue too. Sorry for the long question. Thanks for the help.
ihc49er#2
02-03-2008 08:36:37
 Re: Massey 44 battery in reply to lobelly95, 02-02-2008 12:35:07
you could hook up 10 or 100 6 volts in parallel and its still 6 volts, andy. at leased you would have good amps.thats what your l ooking for to get it started!
Andy Motteberg
02-02-2008 18:31:23
If you hook 2 6V's together, you have a 12V.
Marlowe
02-02-2008 18:38:26
 Re: Massey 44 battery in reply to Andy Motteberg, 02-02-2008 18:31:23
no you don't if you hook the up parallel you still have 6v in series you then have 12
msb
02-02-2008 18:22:04
MH 44 had a group 1 Exide brand battery from the factory.
Texas Denny
02-02-2008 13:07:45
I started my 44 Special for years and years with a 6 volt positive ground system. But it was never an easy start. I eventually switched to positive ground 12 volt and was able to get the generator and regulator to charge the 12 volt battery by adjusting the regulator. Used it that way for another 5+ years before selling it to a friend who is still using it like that. To get extra cranking power, yours may have had two 6 volt in parallel which leaves it at 6 volt.
The 44 and 44 Special start pretty hard on 6 volt unless everything is perfect with the battery and cables (big cables - at least 00). Most users and enthusiasts probably go to 12 volt and an alternator.
