44 Brakes
Steve W.
01-28-2008 13:48:12
I just bought a 44 tractor and the left brake is stuck. How do you get it apart to work on it??
msb
01-28-2008 19:50:35
 Re: 44 Brakes in reply to Steve W., 01-28-2008 13:48:12
Serial number of your 44??
DWF
01-28-2008 18:16:35
Look on the left side of the machine just below and ahead of the clutch pedal. A shaft comes from the right side where the brake pedals are. There is several cotter pins and a spring that comes off, then a big plate with 1/2" bolts (6 or so). When all is loose the plate with the brake mechanism will come off.
DWF
Steve W.
01-28-2008 18:58:49
 Re: 44 Brakes in reply to DWF, 01-28-2008 18:16:35
I took all of that loose and it appears to be froze in the housing. I don't have a manual to tell me how they are built so I did not know what was on the back side of that plate.
DWF
01-28-2008 19:17:16
 Re: 44 Brakes in reply to Steve W., 01-28-2008 18:58:49
The shoes are probably stuck to the drum. Keep working at it to loosen them up.
I think they have manuals at this site, if not Jens Sales has them.
DWF
