Shifter locked up MF 35
Docric
01-27-2008 16:47:29
I was happily grading with with box blade today in low range when I shifter into what I thought was reverse, but when I released the clutch, I was still in some forward gear. The shifter is stuck and I am unable to move it at all. Clutch "feels" fine. Can easily shift from high to low range.
I do not have a good feeling about this.
Any ideas?
Thanks in advance.
Ric
Docric
01-28-2008 12:59:00
 Re: Shifter locked up MF 35 in reply to Docric, 01-27-2008 16:47:29
Many thanks to those who replied!
I never in a million years would have thought this would be an easy fix!
You guys are great.
Ric
135 Fan
01-28-2008 00:10:50
Common problem, easy fix. Lots of info in the archives. Don't lift up on shifter when changing gears. Screw driver or pry bar will solve problem as stated. Dave
JimAg
01-27-2008 19:16:34
Remove transmission oil filler plug. Using a screwdrive, shift the shift rail(round rod toward center of tractor) to neutral and your problem should be temporarily fixed.
Jim
MF#1
01-27-2008 19:03:03
Doc, what Chris pointed you to will be the answer. You may find that not lifting up on the shifting lever when moving it will help prevent this in the future. Or, you have some worn components that need attention. If you do a search here for "stuck shifter" or close you"ll find lots of info on it.
Chris Or.
01-27-2008 17:01:43
This should help you out.
